pacorrtesting1
Introduction
In industries where products rely on strong adhesive bonds—such as packaging, laminates, automotive components, and medical supplies—ensuring the durability and performance of those bonds is critical. A weak adhesive bond can result in product failure, costly returns, and dissatisfied customers.
That's why manufacturers across the world trust Peel Strength Tester from Pacorr to accurately measure the strength of adhesive bonds and ensure product quality.
What is a Peel Strength Tester?
A Peel Strength Tester is a laboratory instrument designed to measure the force required to peel apart two bonded materials. This test helps assess the performance of adhesives, tapes, films, labels, and laminated products under real-world conditions such as handling, transport, and storage.
By conducting peel strength tests, manufacturers can confidently determine if their products meet required quality and durability standards.
Industries That Use Peel Strength Testers
Pacorr's Peel Strength Testers are used across a wide range of industries, including:
Flexible Packaging – Pouches, films, and laminates
Adhesive Products – Tapes, labels, stickers
Medical Supplies – Bandages, surgical tapes, protective films
Automotive Sector – Interior trims, bonded components, insulation materials
Electronics and Appliances – Adhesive films, display laminates
Laminates and Coatings – Multi-layer bonded products
If your product involves adhesives, films, seals, or bonded materials, peel strength testing is essential for quality control.
Why is Peel Strength Testing Important?
Measuring peel strength offers several key benefits:
Ensures product durability and reliability
Prevents adhesive or seal failure during use
Helps meet national and international standards (ASTM, ISO, etc.)
Supports research and development for product improvement
Reduces product failures, customer complaints, and costly recalls
Features of Pacorr Peel Strength Testers
At Pacorr , we design Peel Strength Testing that are accurate, reliable, and easy to operate:
High-precision load cell for accurate force measurement
Digital display for easy-to-read results
Adjustable testing speed for different material types
Sturdy, durable frame for long-term use
Customizable options to meet specific needs
Compliance with global industry quality standards
How Does Peel Strength Testing Work?
The process is straightforward:
Why Choose Pacorr?
Pacorr is known for delivering high-performance, easy-to-use testing instruments backed by expert support:
Industry-leading accuracy and repeatability
Machines designed for operator convenience and safety
Expert technical support and training
Tailored solutions for specific applications
Affordable, durable, and reliable equipment
Conclusion
Adhesive strength plays a vital role in product performance and customer satisfaction. With Pacorr's Peel Strength Tester Price , you can accurately test adhesive bonds, improve product quality, and reduce the risk of failures.
Explore our range of advanced testing instruments at www.pacorr.com or contact our experts today for the right solution for your business.
- The bonded material sample is placed into the machine.
- One end is clamped securely, while the other is peeled away at a constant speed.
- The tester records the force required to separate the materials.
Why Choose Pacorr?
Conclusion
